scar69
Oct 30, 2021Aspirant
Constant Router Disconnect
Since last bios update on my router, my xbox will not stay connected. Constant connect and disconnect, back and forth. My xbox is hard wired, not wifi. Also web pages on both my laptop and desktop...
Oct 30, 2021Guru - Experienced User
- scar69Oct 30, 2021Aspirant
My cable modem is a Motorola Surfboard SB6141. My Nighthawk router is a R8000P.
Everything worked fine before the firmware update
My firmware update was to V1.4.2.84_1.3.42.
That is when everything broke.
Xbox was a constant disconnect. Computers had trouble loading about anywebpage.
I just reverted back to V1.4.1.68_1.3.28, about 30 minutes ago.
Everything went back to working normally.
My 2 tv's and xbox are hardwired to the Nighthawk.
My desktop and laptop and wireless.
There are many other wifi's here. I live in an apartment
- FURRYe38Oct 30, 2021Guru - Experienced User
Next time, try a factory reset and setup from scratch after a FW update.
I guess use whats working for now.
