Notetaker
Mar 17, 2021Aspirant
Control 2 Routers from one phone app
I am installing a second AC1750 WiFi Router. I use the Nighthawk app for the first one. Is there a trick to getting the second router working? Do I need a separate Nighthawk app or is there a way to I...
michaelkenward
Mar 18, 2021Guru - Experienced User
That tells us nothing about your device. AC1750 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
Some devices support Anywhere Access (previously known as Remote Access) and Remote Management.
I have no idea if your unknown kit is one of the AC1750 devices supports that.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Look for the model number on the label on the device.
Check the section in the manual Remote Management.
The there is this:
Enabling your router's remote management | Answer | NETGEAR Support
How do I enable remote access on my router using the Nighthawk app? | Answer | NETGEAR Support
What functions can I manage using remote access in the genie mobile app? | Answer | NETGEAR Support
