Notetaker
Mar 17, 2021Aspirant
Control 2 Routers from one phone app
I am installing a second AC1750 WiFi Router. I use the Nighthawk app for the first one. Is there a trick to getting the second router working? Do I need a separate Nighthawk app or is there a way to I...
Notetaker
Mar 18, 2021Aspirant
Thanks. One of my Routers is a Nighthawk R6700v3, and the other is an R6350. I have since figured out that one app can not manage multiple routers, even if each router individually is accessible through the Nighthawk app. Since I couldn't download a second app on my phone, or download an app to a pc, I had to use another phone.
Now, if I could just figure out how to close this discussion....
- michaelkenwardMar 19, 2021Guru - Experienced User
I don't know how you concluded that. I use the Nighthawk Android app to work with two routers on different networks.
I use Anywhere Access to manage an R7800 and R7000P.
