karlmurphy's avatar
karlmurphy
Controlling Device on LAN
I'm having issues on network when I connect my fetch box to lan via ethernet. When connected via my wi-fi its fine but I would like use ethernet.    My broadband NBN fibre gateway (device) is in th...
  • additude's avatar
    Apr 05, 2020
    OK Karl Murphy,
    Your setup is?:
    FIBER WAN-->NBN fibre gateway (device)-->8 Port TP Switch-->(Hardwired output to 3 seperate locations 1.2.3)-->1. Nighthawk Router, 2. Some other device, 3. Some other device
    I think if this is your setup then this a big problem...
    It should be more like:
    FIBER WAN-->NBN fibre gateway (device)-->Nighthawk Router-->8 Port TP Switch-->To 3 seperate rooms...
    Of course all depending on what ever NBN fibre gateway (device) is and how it is setup?
    Depending on how you have a "Cable Modem/Router" configured?
