jimeeg
Jul 17, 2019Aspirant
Correct setting wireless selection
when using my phone at home to view Utube....phone showing connected to the 2.4G band...is this correct or should connection be to the 5G band ?
- Jul 17, 2019
Greetings,
This depends on your mobile device. Does it have a 5Ghz radio?
If you are going for raw performance and the device has a 5Ghz radio, this band will give best performance from a speed perspective.
If you are looking for best broadcast range, the 2.4Ghz radio will perform best overall.
shadowsports
Jul 17, 2019Hero
Greetings,
- jimeegJul 18, 2019Aspirant
Thank you for the help. I am using a samsung mobile phone to view UTube.
