Brownk's avatar
Brownk
Could you assitance with NMRP Flash on macOS
Never used this before.
I assume there are no system requirements?  I am running macOS 10.13 (High Sierra).  I have installed BREW, the necessary Apple Command Line tools and the latest version of NMRP Flash.  All I need to do is install NMRP Flash, but wish to make sure the latest version is what is should use since I am on a older version of macOS.
Also would like to verify the appropriate port on my R7800 router.  There are 5 ports.  There is one yellow port labelled Ethernet and I assume this is the WAN port?  There are 4 black ports that I assume are the LAN Ports?
Why Netgear doesn't label them as such seems odd.
  • Anybody know the minimal System Requirements?  Figured I was alright installing the app and it was rather involved, only to find out my OS was too old.
    Starting to feel I should just except that the router is lost.  Even though my instincts say it is just corrupted firmware.
  • plemans's avatar
    Use one of the 4x lan ports for flashing with nmrpflash.
    I've never used it on macOS so not much help with that.
