Mrcorvettegolfe
Feb 14, 2021Aspirant
Couldn't get IP address
I have had this router for 2 years no problems until now. Wired devices have connection but wireless can't get an IP address. I have reset the router to factory specs and also have take off all the s...
- Feb 15, 2021
I downloaded the latest version again and installed. All seems to be working now. Thanks.
Feb 14, 2021Guru - Experienced User
What firmware version are you on?
What modem/gateway is it connected to?
Is the wireless broadcasting but just not able to connect? Is it connecting but saying "no internet"
What exactly is happening?
