Mrcorvettegolfe
Feb 14, 2021Aspirant
Couldn't get IP address
I have had this router for 2 years no problems until now. Wired devices have connection but wireless can't get an IP address. I have reset the router to factory specs and also have take off all the s...
- Feb 15, 2021
I downloaded the latest version again and installed. All seems to be working now. Thanks.
Feb 14, 2021Guru - Experienced User
What firmware version are you on?
What modem/gateway is it connected to?
Is the wireless broadcasting but just not able to connect? Is it connecting but saying "no internet"
What exactly is happening?
Mrcorvettegolfe
Firmwave 1.3.1.64_10.1.36 I have automatic update and checked that this was the latest version
I have Optimum cable modem which is an Aris model.
I see that the wireless is broadcasting. It says "couldnt' obtain ip address" All wired devices work fine.
- plemansFeb 14, 2021Guru - Experienced User
What arris modem is it?
You're also not on the latest firmware. the latest is 1.3.2.134https://www.netgear.com/support/product/R7000P.aspx#download
try installing that version over a hardwired connection, do a factory reset, and then clean install.
- MrcorvettegolfeFeb 14, 2021Aspirant
Did what you posted. I installed latest firmware. Then did reset but nothing has changed. All wired devices are connected but wifi couldn't obtain ip address.I have 3 TV's one wired the other two wireless. One is a Insignia/firestick model and when I try to scan for networks it doesn't even show any. The other is a Samsung Smart TV and I was able to connect to the internet and when I tried Netflix it loaded but when I clicked on something to watch I get an error message. Also the same with HBOmax.
I tested the speed of cable modem and it is 75mbs. This is driving me crazy. I have reset modem also. I have to buy another Nighthawk or my wife will kill me and grandchildren when they come. What no Mario Brothers Grandpa!!!
- plemansFeb 14, 2021Guru - Experienced UserYou still haven't put what model modem it is
