Mrcorvettegolfe
Feb 14, 2021Aspirant
Couldn't get IP address
I have had this router for 2 years no problems until now. Wired devices have connection but wireless can't get an IP address. I have reset the router to factory specs and also have take off all the s...
- Feb 15, 2021
I downloaded the latest version again and installed. All seems to be working now. Thanks.
Mrcorvettegolfe
Firmwave 1.3.1.64_10.1.36 I have automatic update and checked that this was the latest version
I have Optimum cable modem which is an Aris model.
I see that the wireless is broadcasting. It says "couldnt' obtain ip address" All wired devices work fine.
Feb 14, 2021Guru - Experienced User
What arris modem is it?
You're also not on the latest firmware. the latest is 1.3.2.134
https://www.netgear.com/support/product/R7000P.aspx#download
try installing that version over a hardwired connection, do a factory reset, and then clean install.
