Mrcorvettegolfe
Feb 14, 2021Aspirant
Couldn't get IP address
I have had this router for 2 years no problems until now. Wired devices have connection but wireless can't get an IP address. I have reset the router to factory specs and also have take off all the s...
- Feb 15, 2021
I downloaded the latest version again and installed. All seems to be working now. Thanks.
Feb 15, 2021Guru - Experienced User
The only other thing I'd try is installing version 1.3.0.20 of the firmware. Again, do it over a hardwired connection, do a factory reset, then a clean install of the router (not from a backup configuration).
Mrcorvettegolfe
Feb 15, 2021Aspirant
