VJOGuy
Nov 13, 2021Aspirant
Creating a custom DNS Server
Keeping in mind that I'm a novice with routers and such... I've been told I need to create "Custom DNS Server" on my Netgear router. I have zero idea how to do this, or even what it means.
Would anyone be able to provide me with step-by-step guidance on that? Googling it is just creating more confusion with terms like Dynamic DNS and Static DNS, etc. As I mentioned, I'm clueless with this stuff! I do know how to log in to my Router web interface and engage in very minor tweaks. But that's it!
Any assistance would be super appreciated!
Thank you!!
Chris
Are you sure I haven't exhausted those avenues already?
I've asked one question. I have zero answers to it. In the process of asking, I've answered three questions, none of which help solve the problem at hand, nor get any closer to answering my question.
The suggestion to start from the beginning by stating what the problem attempting to be solved is, is fair. However, I've done that...for months to this point in time.
The question is NOT whether you think my request for instructions will or will not solve the problem! The question is, can you tell me how to do that? It begs a simple response...yes...or no! And if yes, what are the instructions. The rest, my friends, is extraneous and opinions that were not being sought.
Instead, we've now wasted 24 hours with answering questions with questions. This, friends, is why these boards are often frustrating to the average human being! Next time, just try answering that damn question, and leave it at that!
No need to respond. It's clearly not possible.
Why?
Start with what you really want to achieve rather than someone else's idea of the solution.
- VJOGuyAspirant
Okay. I've got T Mobile Home Internet service. The T Mobile modem (made by Nokia, I believe) doubles as a wi-fi router. I'm told from having posted here in the past that it has created a double NAT problem (where my internet speeds either slow. Or there appears to be zero connection (webpages just don't load), when in fact there is).
The TMobile/Nokia modem/router has limited options for configuring. For example, there is no Bridge mode option available. And while I have turned off the WiFi on the TMobile modem/router, I've since come to learn that NAT is behind the wifi/ethernet bridge (lan), in the firewall between tmobile network (wwan) and wifi/ethernet bridge(lan). So turning WiFi off doesn't resolve the issue. In fact, apparently the TMObile modem/router continues to emit it's own single Wi-Fi signal...even with Wifi shut off.
In the past, someone suggested that I just put the Netgear router in to AP mode. But in doing so, that shut off the Armor protection that I want to keep active. So that isn't an option either.
I've spent some time on another board trying to resolve the TMobile issue. Someone who is well respected on that board, and also produces a ton of YouTube videos on it, and who himself also has a Netgear system, says I should try doing a custom DNS server on my netgear to avoid the tmobile DNS routing.
This is the problem, and where I am at this point.
Now I see the point.
Might be better to look for solutions to "double NAT" rather than custom DNS Server.
What is Double NAT? | Answer | NETGEAR Support
and
How to fix issues with Double NAT | Answer | NETGEAR Support
It might also help to tell people what this T Mobile modem is. Maybe someone else has already wrestled with one.
