VJOGuy
Nov 13, 2021Aspirant
Creating a custom DNS Server
Keeping in mind that I'm a novice with routers and such... I've been told I need to create "Custom DNS Server" on my Netgear router. I have zero idea how to do this, or even what it means. Woul...
- Nov 14, 2021
Are you sure I haven't exhausted those avenues already?
I've asked one question. I have zero answers to it. In the process of asking, I've answered three questions, none of which help solve the problem at hand, nor get any closer to answering my question.
The suggestion to start from the beginning by stating what the problem attempting to be solved is, is fair. However, I've done that...for months to this point in time.
The question is NOT whether you think my request for instructions will or will not solve the problem! The question is, can you tell me how to do that? It begs a simple response...yes...or no! And if yes, what are the instructions. The rest, my friends, is extraneous and opinions that were not being sought.
Instead, we've now wasted 24 hours with answering questions with questions. This, friends, is why these boards are often frustrating to the average human being! Next time, just try answering that damn question, and leave it at that!
No need to respond. It's clearly not possible.
VJOGuy
Nov 14, 2021Aspirant
Thank you.
The T Mobile Modem is a Nokia 5G21-12W-A.
According to the manual that came with it (and others have also confirmed), it has no Bridge mode capacity, which admittedly would make many things so much easier!
And as mentioned previously, placing the Netgear router in AP mode will disable other features I'm paying for, thus creating yet another new problem I'd prefer to avoid.
Unfortunately, both articles suggest either Bridge mode and/or AP mode as a solution. I wish either was an option for me, but they are not.
Is there harm in creating a DNS server to attempt to resolve the issue? If not, would you be able to help me with that?
Thanks!
Chris
Nov 14, 2021Guru - Experienced User
Does the nokia have a DMZ?
if you put the netgears IP address into the Nokia's dmz, it should automatically forward all traffic.
- VJOGuyNov 14, 2021Aspirant
It does not (at least, when I search the manual using "DMZ" as the search paramteter, nothing comes back). Also not seeing it in the index. From what I'm reading, no one seems to like this router/modem as it has very little customizeability.
Still back to the original question...can a Custom DNS Server be created? And if so, is it possible to easily explain the process?
- plemansNov 14, 2021Guru - Experienced User
I'm still not sure what you think running your own dns is going to achieve.
- michaelkenwardNov 14, 2021Guru - Experienced User
That's my question.
Coming up here with a "how do I do this on my router?" answer is often less productive than lobbing a problem, what you want to achieve (eliminate double NAT), into the maw.
I'd be tempted to try this:
Search - NETGEAR Communities – Nokia 5G21
Most issue like that have come up somewhere else. And problems with third party hardware may be best attacked in the outside world where there is likely to be more experience.
I'd also go to the ISP's support site, if there is one. This wont be a Netgear only issue. Anyone seeking to use a decent router with this modem/router will be in the same boat
