Batesraintree's avatar
Aug 05, 2021
Credit card processor questions
My credit card processor has questions I can not answer. Can you help me with getting them the righrt information for them?? Here's their questions about my Netgear R7000P  router:
"Can your organization confirm the following? A) Properly configured internal network firewalls/routers and/or strong Access Control Lists (ACLs) block traffic from all source addresses to the undetected target(s), as mandated by your organizational security policy? B) Active security measures (Such as IPS, or WAFs and NOT the Firewall Itself), if they exist, are whitelisted for Securetrust's scan traffic?"
Thank you for your help
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Are you using some sort of widget to process credit card payments?
    Do they want answers before they let you sign up?
    The R7000P is a conventional consumer grade router with the sort of specification expected for that sort of device. Details are in the documentation:
    Visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    Business grade hardware may well have fancier security.
