Tex2000
Jan 23, 2021Initiate
Csrss.exe malware
The firmware in my Orbi was updated this morning and now I can't connect to the Internet. I talked to Tech Support who told me I have the csrss.exe malware on my network and Orbi will block Internet ...
antinode
Jan 24, 2021Guru
> Model: RBR50|Orbi AC3000 Tri-band WiFi Router
RBR50[v1] or RBR50v2? Look for "Model" on the product label.
Firmware version? Connected to what?
> [...] I talked to Tech Support [...]
Whose? How, exactly? Did you do _anything_ other than start at
http://support.netgear.com/ ?
> [...] who told me I have the csrss.exe malware on my network and Orbi
> will block Internet access until this is resolved. [...]
Sounds very unlikely to me.
> [...] Any idea if non-PC's (phones, tablets) can host this malware?
A quick Web search (for "csrss.exe") suggests that the real thing is
a Windows component.
Look for "Tech support scammers"?
A better start might be to visit http://netgear.com/support , put in
your (actual) model number, and look for Documentation. Get the User
Manual. Read. Look for the LED descriptions and "Troubleshoot".
