yahtzee
Aug 26, 2023Tutor
Current Firmware update for my R7000 AC1900
When I check to see if my R7000 AC1900 router firmware is up to date from the web admin page, it says there are no new updates. The firmware listed there is v1.0.9.88_10.2.88. When I check the Netg...
- Aug 27, 2023
Thanks. Firmware update worked.
michaelkenward
Aug 27, 2023Guru - Experienced User
yahtzee wrote:
What is going on here? Should I install v1.0.11.136?
You have discovered that the "on board" update check is not reliable.
It may be that your installed version is so old that it can't see the newest updates.
By all means install the new firmware. Bit be warned that there are times when the changes are so big that you have to install an intermediate update before you can go all the way.
You have missed 10 versions over the past three years. It should work, but don't panic if it doesn't.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
