Uno_Time
Nov 27, 2021Aspirant
Customize Wifi Network issues on 2.4Ghz on a Netgear Nighthawk Tri-Band Mesh (MK83)
Hey, I am having issues with Customize Wi-Fi Network. Below is some of the stats HW: Netgear Nighthawk Tri-band Mesh MK83 Firmware: Vi.1.6.10_3.1.97 Wi-Fi Channel is set to Auto Guest Ne...
Nov 28, 2021Guru - Experienced User
Did you ever try installing the latest firmware and then doing a factory reset/reinstall? During the new setup, don't use a backup configuration. Sometimes old settings can cause issues and a factory reset will clear those out.
- Uno_TimeNov 28, 2021Aspirant
Hey,
Yes I did. I did a reset with the button on the back and reset using the software menu.
Thanks,
Uno
- plemansNov 28, 2021Guru - Experienced User
what modem/gateway is it connected to?
Are you using a switch in your system and if so, what one?
Yes,
My home is setup by 3 floors. Each floor has either a NETGEAR 8-Port Gigabit Ethernet Unmanaged Switch (GS308) or a NETGEAR 5-Port Gigabit Ethernet Unmanaged Switch (GS305).
Thanks,
Uno
