Uno_Time
Nov 27, 2021Aspirant
Customize Wifi Network issues on 2.4Ghz on a Netgear Nighthawk Tri-Band Mesh (MK83)
Hey, I am having issues with Customize Wi-Fi Network. Below is some of the stats HW: Netgear Nighthawk Tri-band Mesh MK83 Firmware: Vi.1.6.10_3.1.97 Wi-Fi Channel is set to Auto Guest Ne...
michaelkenward
Nov 28, 2021Guru - Experienced User
It doesn't usually matter – many questions are generic and apply to most routers – but the MK83 isn't one of the standard Nighthawk WiFi Routers covered in this section. It is Mesh, which seems to be a part of your issue.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Mesh System - NETGEAR Communities
Uno_Time
Nov 28, 2021Aspirant
Will do, Thanks
