FJGoodwin
Jul 15, 2016Aspirant
D7000 and R7000 management
I have a D7000 and wish to set up a R7000 in bridge mode at the other end of the house. Can anyone please offer advice on how to achieve this? Netgear Genie precludes me from accessing the R7000 as...
- Jul 25, 2016
If you are using the desktop version of Netgear Genie, then I'm not familiar with it. What you can do, however, is this. Disconnect the R7000 from everything except power and connect a single computer to it (via a LAN port, if possible, but through one of the R7000's Wi-Fi networks is acceptable). Then, try routerlogin.com via a browser. You should be able to log in and enable bridge mode. There will be an option to specify how the R7000 obtains an IP address for itself. If you opt for the default (DHCP), then you should, later, log onto your D7000 and set up an address reservation to assign a stable address for the R7000.
FJGoodwin
Jul 28, 2016Aspirant
Thankyou to both The Ether and JamesGL for their helpful replies. With your combined advice I have been able to resolve my issue.
- JamesGLJul 28, 2016NETGEAR Employee Retired
Hi FJGoodwin,
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
JamesGL
Community Team
