mattpisti's avatar
mattpisti
D7000 Readyshare problems
Hi, I have a D7000  with a recently loaded firmware V1.0.1.80_1.0.1
my NB with WIN10 Version 20H2 (OS Build 1942.1288) was connecting to Readyshare USB drives w/o issues with and without password protection, all operations were OK: read/write files and folders, deleting etc. However, after updating the D7000 Firmware (Unfortunately I have not saved the details of the previous version) the USB drives  are still visible and accesible also from DLNA but  the files/folders become read only and I cannot change them or remove the read only flag. When I try to write/delete a file/folder, I get a message stating "You need permissions from Readyshare\root to make changes to this file/folder"
I tried safely removing and reconnecting them (running a check disk from win10 before reconnecting) but still "You need permissions from Readyshare\root to make changes to this file/folder". The strange thing is that I can still save on the Readyshare drives the files coming from downloads using Firefox/Chrome.
I tried the different fixes suggested in the community with no success.
Please help
1 Reply
