KMT88
Dec 14, 2019Aspirant
D7000 Sky Ultrafast Broadband
I have just had Sky ultrafast broadband(g.fast) (145+) installed and want to use the D7800(latest firmware). I have gone through the advice of various forums and it still does not connect. This ...
- Dec 14, 2019
I'm afraid the D7800 doesn't support G.fast...
antinode
Dec 14, 2019Guru
> Model: D7800|Nighthawk X4S - AC2600 WiFi VDSL/ADSL Modem Router
Which is it? Look at the product label.
> want to use the D7800 [...]
Use as a modem? Why? Have you found any evidence that the D7800
supports g.fast?
> [...] (latest firmware). [...]
As always, an actual version number would be more useful than your
opinion of what's "latest" today.
> [...] I have gone through the advice of various forums [...]
Think, for a moment, about how little useful information that
non-description conveys to the non-psychics in your audience.
> [...] and it still does not connect. [...]
What kind of "not connect" is this? LED indicators? Error messages?
Any useful information at all?
> Option 61 - 1234567891011@skydsl|89a12345
Traditionally, Netgear firmware has had trouble with some special
characters in PPP credentials, so I would not be amazed if that "|"
caused trouble there. If, that is, the physical DSL link were good. I
wouldn't bet on it, but you might try adding a "\" before the "|".
KMT88
If you have nothing valuable to say, instead of wasting my time and yours just leave the keyboard alone!
A much better answer would of just been, do you know if the netgear D7800 supports G.Fast?
And yes the username is correct based on previous posts on this forum.
The reason I mentioned the latest firmware is because it is based on the website not my own opinion.
And one last thing, the model type is correct, the reason I know is because I copied it off the Netgear website!AC2600 Nighthawk® X4S VDSL/ADSL Modem Router
802.11ac Dual Band GigabitEnjoy Faster Speeds and Simultaneous Streaming
Nighthawk X4S AC2600 WiFi VDSL/ADSL Modem Router with MU-MIMO and Quad Stream technology delivers WiFi to multiple devices simultaneously for faster speeds. Get ultimate WiFi speeds of up to 2.53Gbps, with a powerful 1.4GHz dual core processor. Enjoy smoother streaming and gaming by prioritizing application and device with Dynamic QoS. Includes auto detection for universal DSL support, compatible with VDSL, VDSL2, ADSL, ASDSL2, and ADSL2+. Features such as NETGEAR genie® remote access, ReadyCLOUD® , OpenVPN, and Kwilt app support help you manage your network, have access to a secure personal cloud, access home network remotely, and share photos stored on the storage from anywhere. Using Amazon Alexa™, control your home network with voice commands.Model: D7800
- hushcodenDec 14, 2019Luminary
KMT88 wrote:If you have nothing valuable to say, instead of wasting my time and yours just leave the keyboard alone!
Agreed !!!
Indeed, you can use a generic string in the DHCP 61 field so yours would be 123456789101@skydsl|89a12345
That being said, I'm pretty sure the D7800 doens't support G.fast, so you won't be be able to get a connection...
- KMT88Dec 15, 2019Aspirant
Many thanks, this router will soon appear on ebay :)
