akanoodles
Dec 21, 2021Aspirant
D7000v2 and 5GEE wifi/router
I have a Nighthawk D7000v2 and I'm using it via a Landline. But I'm looking to switch to a 5GEE wifi/router either this one or this one.
Does anyone know how to set this up? I have a bunch of LAN connected devices and want to maintain the stability
Netgear has set up a community forum specifically for the DSL Modem products. Most of the people who watch that forum are more likely to have experience with DSL modems and know how to work it better than those of us who follow this forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/DSL-Modems-Routers/bd-p/home-dsl-modems-routers
Thank you. - michaelkenwardGuru - Experienced User
A lot will depend on the capabilities of whatever mobile router you buy.
As you won't be using the D7000v2 as a modem, there doesn't seem to be much point in visiting the DSL modem section. (Strange suggestion.) What you need help in is using the D7000v2 as a router, which is a simple task.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Check the section in the manual Set Up the Modem Router for Cable or Fiber Service.That will take you back to the settings you need to configure on the new modem. A better place to seek help on this is probably here:
Mobile Routers, Hotspots & Modems
They may not talk about the modem you have in mind, but a router to a mobile modem is a general topic crops up there from time to time.
Those links go nowhere unless you login to EE.
- akanoodlesAspirant
I found this page:
https://kb.netgear.com/29327/How-to-set-D6220-D7000-to-pure-bridge-or-DSL-modem#
I think what I need to do is set this up as a Pure Bridge. How do I do this?
What are you trying to achieve now?
Your first message said:
I'm looking to switch to a 5GEE wifi/routerI interpreted that as meaning that you want to ditch the D7000v2 DSL modem/router and replace it with a mobile modem/router. The broken links you provided to EE end up with devices that work on the mobile phone network. That has nothing to do putting a DSL modem.router into "bridge mode".
If the idea is to use the D7000v2 as a router behind a mobile modem, then bridge mode on the D7000v2 , as described in that KnowledgeBase article, isn't what you want.
I have already explained how to find out how to use the D7000v2 as a router. You will have to work out for yourself how to use whatever mobile device you buy with a router. That is why I suggested that you consult the section here that covers mobile devices.
The other alternative with a mobile front end before your router is to use the D7000v2 as a wireless access point. You can also read about that in the manual for your Netgear modem/router.
