crea2k3
Apr 15, 2021Follower
D7000v2 not getting ip address when connecting via vpn
Hi, I am trying to setup open vpn with my router. It connects, but I am not getting an ip address and cannot ping anything on the network.
Here is the error log :
2021-04-15 23:20:36 WARNING: Compression for receiving enabled. Compression has been used in the past to break encryption. Sent packets are not compressed unless "allow-compression yes" is also set.
2021-04-15 23:20:36 DEPRECATED OPTION: --cipher set to 'AES-128-CBC' but missing in --data-ciphers (AES-256-GCM:AES-128-GCM). Future OpenVPN version will ignore --cipher for cipher negotiations. Add 'AES-128-CBC' to --data-ciphers or change --cipher 'AES-128-CBC' to --data-ciphers-fallback 'AES-128-CBC' to silence this warning.
2021-04-15 23:20:36 OpenVPN 2.5.1 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Feb 24 2021
2021-04-15 23:20:36 Windows version 10.0 (Windows 10 or greater) 64bit
2021-04-15 23:20:36 library versions: OpenSSL 1.1.1j 16 Feb 2021, LZO 2.10
Enter Management Password:
2021-04-15 23:20:36 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
2021-04-15 23:20:36 TCP/UDP: Preserving recently used remote address: [AF_INET]**.***.***.**:12974
2021-04-15 23:20:36 UDP link local: (not bound)
2021-04-15 23:20:36 UDP link remote: [AF_INET]**.***.**.**:12974
2021-04-15 23:20:37 [netgear] Peer Connection Initiated with [AF_INET]**.***.**.**:12974
2021-04-15 23:20:38 open_tun
2021-04-15 23:20:38 tap-windows6 device [NETGEAR-VPN] opened
2021-04-15 23:20:38 Successful ARP Flush on interface [44] {17FC037D-B1D7-4261-8122-5B9F30592E09}
2021-04-15 23:20:38 Warning: route gateway is not reachable on any active network adapters: 192.168.16.254
2021-04-15 23:20:38 WARNING: OpenVPN was configured to add an IPv4 route. However, no IPv4 has been configured for NETGEAR-VPN, therefore the route installation may fail or may not work as expected.
2021-04-15 23:20:38 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
2021-04-15 23:20:38 Initialization Sequence CompletedThis is my config file :
client dev tap proto udp sndbuf 393216 rcvbuf 393216 push "sndbuf 393216" push "rcvbuf 393216" dev-node NETGEAR-VPN remote **.***.**.** 12974 route-gateway 192.168.16.254 resolv-retry infinite nobind persist-key persist-tun ca ca.crt cert client.crt key client.key cipher AES-128-CBC comp-lzo verb 1
No RepliesBe the first to reply
