Matty100
Sep 06, 2021Initiate
D7000v2 UPnP stops working
Hi all,
Currently using a D7000v2 with the latest firmware (V1.0.0.74_1.0.1). I'm trying to get UPnP to work on the router settings however it only ever works for an hour or so after a factory reset after which the UPnP table stops updating. If I try turn UPnP off and on again without doing a Factory Reset, the table just stays blank and never refreshes.
I know it isn't working because my NAT type is Open in games when the table is populating. My NAT Type then changes to Moderate once it stops working. I am on a wired connection.
The Advertisement Period (in minutes) and Advertisement Time to Live (in hops) are on 30 and 4 which are the default values. Unsure if I should change this?
Has anyone else experienced this? Is there a firmware I can roll back to that doesn't have this issue?
Thanks in advice for any help!
1 Reply
- Matty100Initiate
Guess not even Netgear know how to fix it...
