mark8par's avatar
Apr 06, 2017
D7800 & R7800 AP Mode
I recently purchased a D7800 modem router and decided to add the R7800 to increase wireless around my home.  The problem is that when I set the R7800 in AP mode and login to the router settings, it s...
  • mark8par's avatar
    mark8par
    Apr 06, 2017
    I think I managed to sort it.
    On the R7800 Selected advanced settings - Router/AP/Bridge Mode - AP Mode.  At  this point selected use fixed address, restarted and DHCP was off.
    On the D7800 (main modem router) in lan setup - reserved the ip address for the R7800
    Lety see how it goes.
    Thanks for your help :)
