mark8par
Apr 06, 2017Star
D7800 & R7800 AP Mode
I recently purchased a D7800 modem router and decided to add the R7800 to increase wireless around my home. The problem is that when I set the R7800 in AP mode and login to the router settings, it s...
- Apr 06, 2017
I think I managed to sort it.
On the R7800 Selected advanced settings - Router/AP/Bridge Mode - AP Mode. At this point selected use fixed address, restarted and DHCP was off.
On the D7800 (main modem router) in lan setup - reserved the ip address for the R7800
Lety see how it goes.
Thanks for your help :)
mark8par
Apr 06, 2017Star
If I connect lan to lan the internet connection light will not come on, on the r7800
Apr 06, 2017Guru - Experienced User
It's not supposed to. The Internet LED is for the WAN port. In this configuration, the WAN port is not used. LAN settings are not needed since DHCP services will be coming from your D7800. This is ok.
