LaddieParker's avatar
Nov 17, 2020
D7800 won't connect at 1733 mbps on 5GHZ
I have a D7800 and a Gigabyte GC-WB1733D-I PCIE addon card. Both support 1733 mbps wireless connection on the 5GHZ band, but the maximum connection speed that i can acheive is 866.7 mbps.   On the ...
  • plemans's avatar
    Nov 17, 2020
    Your GC-WB1733D-I  supports 1733mbps when running in 160hz mode. And its only a 2x2 antenna setup.
    The D7800 supports 1733mbps when running 80hz channel bandwidth AND using a 4x4 antenna setup.
    So since you only have a 2x2 wireless chip, your max connection is the 866mbps link speed. (link speed isn't the same and throughput).
