Chestersam's avatar
Chestersam
Follower
Nov 18, 2018
D8500 - Bridge Mode option doesn't appear
Help please - D8500 Nighthawk AC5300 Wifi Modem Router "use other operation mode" check box and enable bridge mode radio button are not showing in the Advanced>Advanced Setup>Wireless Settings menu...
  • michaelkenward's avatar
    Nov 18, 2018
    Bridge mode can mean several things. Modem only mode to feed a router, wifi bridge to be a repeater. Which are you after?
    There is a manual for the D8500 somewhere at the end of this link:
    >>>> D8500 | Product | Support | NETGEAR <<<<
    By the way, you have posted your message in the section of this community given over to
    Nighthawk WiFi Routers
    The D8500  is a DSL Modem/Router.
    You might get better replies, and find other answers, over in the appropriate section:
    DSL Modems & Routers
