Barvel-A
Jan 27, 2020Guide
Daily Reboot of R7900p
Hello, I have had my router in place for 3 weeks and now daily, if not x2 or x3 I have to power down for 10-15 min. in reading the threads this is not uncommon. but I don't see a resolution wit...
- Jan 27, 2020
here's what I'd try and the order
1. factory reset the router. the version you're on removed many features. don't install from backup.
2. downgrade to V1.4.1.30. do it over a hardwired connection and reset the router afterwards. Again, don't install from backup.
michaelkenward
Jan 28, 2020Guru - Experienced User
Barvel-A wrote:
Hello,
Why? What is happening that prompts you to do this?
It might also help if you told people what the modem is in front of this router, if there is one. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router.
- Barvel-AFeb 07, 2020Guide
michaelkenward Thanks for that.
I have been doing this for 30+ years and that is a rookie move putting the modem on the wrong side.There are no prompts. It just stops.
There is nothing in the event logs to refer to after the reboot because they are wiped.
I did see this after my reboot;
[DoS attack: ACK Scan] from source 198.255.6.34,port 21047 Thursday, Feb 06,2020 21:28:07
But those are common to any router. Some one is always trying to hack in.
- michaelkenwardFeb 07, 2020Guru - Experienced User
IP Addresses Report
Created by using IPNetInfo
Order 1 IP Address 198.255.6.34 Status Succeed Country USA - California Network Name FOSCAM Owner Name ShenZhen Foscam Intelligent Technology Co., Ltd From IP 198.255.6.32 To IP 198.255.6.39 CIDR 198.255.6.32/29 Allocated Yes Contact Name ShenZhen Foscam Intelligent Technology Co., Ltd Address Room AB
9/F
Block F5
TCL International E City
No.
1001 Zhongshan
ShenzhenPostal Code 518055 Email support@foscam.com Abuse Email support@foscam.com Abuse Contact Phone +86-755-26745668 Fax Whois Source ARIN Host Name Resolved Name
