Barvel-A
Jan 27, 2020Guide
Daily Reboot of R7900p
Hello, I have had my router in place for 3 weeks and now daily, if not x2 or x3 I have to power down for 10-15 min. in reading the threads this is not uncommon. but I don't see a resolution wit...
- Jan 27, 2020
here's what I'd try and the order
1. factory reset the router. the version you're on removed many features. don't install from backup.
2. downgrade to V1.4.1.30. do it over a hardwired connection and reset the router afterwards. Again, don't install from backup.
Jan 27, 2020Guru - Experienced User
