Barvel-A
Jan 27, 2020Guide
Daily Reboot of R7900p
Hello, I have had my router in place for 3 weeks and now daily, if not x2 or x3 I have to power down for 10-15 min. in reading the threads this is not uncommon. but I don't see a resolution wit...
- Jan 27, 2020
here's what I'd try and the order
1. factory reset the router. the version you're on removed many features. don't install from backup.
2. downgrade to V1.4.1.30. do it over a hardwired connection and reset the router afterwards. Again, don't install from backup.
Barvel-A
Feb 07, 2020Guide
michaelkenward Thanks for that.
I have been doing this for 30+ years and that is a rookie move putting the modem on the wrong side.
There are no prompts. It just stops.
There is nothing in the event logs to refer to after the reboot because they are wiped.
I did see this after my reboot;
[DoS attack: ACK Scan] from source 198.255.6.34,port 21047 Thursday, Feb 06,2020 21:28:07
But those are common to any router. Some one is always trying to hack in.
michaelkenward
Feb 07, 2020Guru - Experienced User
IP Addresses Report
Created by using IPNetInfo
| Order | 1 |
| IP Address | 198.255.6.34 |
| Status | Succeed |
| Country | USA - California |
| Network Name | FOSCAM |
| Owner Name | ShenZhen Foscam Intelligent Technology Co., Ltd |
| From IP | 198.255.6.32 |
| To IP | 198.255.6.39 |
| CIDR | 198.255.6.32/29 |
| Allocated | Yes |
| Contact Name | ShenZhen Foscam Intelligent Technology Co., Ltd |
| Address | Room AB 9/F Block F5 TCL International E City No. 1001 Zhongshan Shenzhen |
| Postal Code | 518055 |
| support@foscam.com | |
| Abuse Email | support@foscam.com |
| Abuse Contact | |
| Phone | +86-755-26745668 |
| Fax | |
| Whois Source | ARIN |
| Host Name | |
| Resolved Name |
