Barvel-A
Jan 27, 2020Guide
Daily Reboot of R7900p
Hello, I have had my router in place for 3 weeks and now daily, if not x2 or x3 I have to power down for 10-15 min. in reading the threads this is not uncommon. but I don't see a resolution wit...
- Jan 27, 2020
here's what I'd try and the order
1. factory reset the router. the version you're on removed many features. don't install from backup.
2. downgrade to V1.4.1.30. do it over a hardwired connection and reset the router afterwards. Again, don't install from backup.
Barvel-A
Feb 07, 2020Guide
I spoke to soon.
This morning I had to reboot and just now I had to do it again.
plemans Any other options.
ValricoJoe
Feb 14, 2020Aspirant
Good luck getting this to stop happening, based on my fighting with two of the units, hours wasted on tech support, I took them back and got a refund, looking to suppliment my FIOS Aeris router, just have not found a replacement yet.
Good luck setting static ip addresses and locking down the router, after a couple dozen times or having to set up the router, I gave up, took all of them back to Costco. Look at the threads on this POS, all have the same problems and Netgear has not resolved.
