devourbert
Sep 09, 2022Guide
daily wifi dropouts
Good morning, Almost on a daily basis, I have to restart my router because the WiFi doesn't work: devices are still connected to the router, but there is no internet (e.g. on the phone the wifi s...
- Sep 10, 2022
devourbert wrote:
but the router interface couldn't connect.
What does that mean? Some sort of error message? Or nothing happened?
The automated update process is not infallible, especially when there are several updates for it to take in.
I have now manually downloaded the latest version and installed it. I hope this will fix the issue.You may have to reset and reconfigure the router if the problem persists.
I don't have the modem details at hand (it sits in the garage), but the thing is that the whole set-up worked well for years. I hope the new firmware will resolve the daily drop-outs.That could be essential detail. Something that worked fine for years can still go wrong if modem and router end up rebooting themselves in ways that scramble their settings.
devourbert
Sep 09, 2022Guide
Thank you!
Funny enough: automatic firmware updates were enabled
.. but it obviously didn't update anything! I clicked on "check internet" , but the router interface couldn't connect. I have now manually downloaded the latest version and installed it. I hope this will fix the issue.
Thanks!
Heiko
michaelkenward
Sep 10, 2022Guru - Experienced User
- devourbertSep 17, 2022Guide
Hello!
It seems the new firmware has resolved the issue.. fingers crossed.
Cheers!
PS: When I said "nothing happened": it was trying to get the new firmware, but nothing happened... no error message, no progress,...
