Markg2's avatar
Markg2
Tutor
Jan 23, 2016
Data transfer rate computer to Netgear USB flash drive port--Ethernet
AC1900--   Assming the computer and AC1900 are ethernet connected vs. wireless and I intend to copy large amounts of data to a 3.0 flash drive in the 3.0 USB router port, what is a realistic data--...
  • TheEther's avatar
    Jan 23, 2016
    If you can believe the test results for FAT32 Write - USB 3.0, then you'll get about 33 MB/s (Megabytes per second) for the R7000.  TBH, that's pretty miserable.  The top performing router on that list can do over 84 MB/s.
    I would wager that the limiting factors are a combination of the CPU speed, firmware efficiency, shielding of the USB 3.0 port against Wi-Fi interference and the raw speed of the drive.
