popcorn9499
Jul 11, 2016Aspirant
Date and time not getting set correctly
So ive been having problems with my router not getting date and time correctly. I got this router from the store a few weeks ago. Only had one fairly minor issue with it. the network assigned time is...
- Sep 21, 2016
ya the fix was update to the newer version 1.0.7.2_1.1.93 and the system time corrected itself
popcorn9499
Just wanted to update and say factory reset didnt work
Retired_Member
Jul 12, 2016How is the router connected to modem, The Wan port must be used. What modem are you using.
- popcorn9499Jul 12, 2016Aspirant
in response to searay yes the wan port is being used and before I did the firmware upgrade on the nighthawk from the firmware it orriginally came with the time syncronization worked then on the old version. It quit working on the new version. Sadly idk the version it used to be running. And The modem isnt a modem Its a router that my isp gave us put into lan subports so our tv system still works. But like I said it worked before. it was a pace 5168n router though.
- Retired_MemberJul 12, 2016
go to router status and verify the WAN IP is NOT 192.168.1.x or 10.0.0.X it should be a Public IP
yes it is my publice ip this picture should be evidence of that.
IP Address: 207.161.xxx.xxx
Subnet Mask: 255.255.252.0
DNS Address: 142.161.2.155
142.161.130.155
