popcorn9499
Jul 12, 2016Aspirant
Date and time not getting set correctly
So ive been having problems with my router not getting date and time correctly. I got this router from the store a few weeks ago. Only had one fairly minor issue with it. the network assigned time is...
- Sep 21, 2016
ya the fix was update to the newer version 1.0.7.2_1.1.93 and the system time corrected itself
soyee7
Sep 20, 2016Apprentice
Were you ever able to get this corrected at all? If so, what was the fix?
ElaineM
Sep 20, 2016NETGEAR Employee Retired
soyee7 Do you have the same model number of the router?
Did you already update the firmware of the router?
Have you tried factory reset?
- soyee7Sep 21, 2016Apprentice
I have an R7500 (AC2350). Yes, I have the latest firmware on the router. I have even tried downgrading and re-upgrading the firmware as well. Yes, I performed a factory reset. Here is a link to my post on this.
Thanks,
Sasan
