pvradu
Oct 28, 2017Guide
DDNS not working for Mynetgear.com domains. Domain owned by Network Solutions LLC
Ok, discovered this morning that mynetgear.com it's registered by NetworkSolutions LLC. http://whois.domaintools.com/mynetgear.com Registrar Network Solutions, LLC. Registrar Status clientT...
- Nov 08, 2017
Hi,
problem was solved 1-2 days after posting the message.
Jin357
Oct 28, 2017Guide
Same problem here. As others have noted, any A records for mynetgear.com are resolving to 208.91.197.27. Doing some brief digging, that IP is associated with tons of domains (over a million) which don't seem to have any relation to Netgear. No idea what's going on here, but I suppose it's possible they shut down the service without notifying anyone.
Could someone please post if you get in contact with Netgear support? I can't physically get to my router at the moment and didn't see a support contact without providing a serial number.
