pvradu
Oct 28, 2017Guide
DDNS not working for Mynetgear.com domains. Domain owned by Network Solutions LLC
Ok, discovered this morning that mynetgear.com it's registered by NetworkSolutions LLC. http://whois.domaintools.com/mynetgear.com Registrar Network Solutions, LLC. Registrar Status clientT...
- Nov 08, 2017
Hi,
problem was solved 1-2 days after posting the message.
Jin357
Oct 28, 2017Guide
To add to what I've already tried, I logged into my noip.com account with the same credentials as the mynetgear.com ddns configuration in the router and added a new host myhost.ddnsking.com. I then disabled dynamic DNS on the router itself and changed the myhost.mynetgear.com host in the noip.com configuration to be a CNAME pointed to myhost.ddnsking.com. I've been checking global propogation periodically and it will occasionally propogate to one name server in Brazil before reverting back after a few minutes. It seems that the Network Solutions DNS configuration keeps overriding the noip CNAME so it never propogates globally. Just more weirdness to add to the mix.
- solidus1983Oct 28, 2017Initiate
I am also having the same issue where the DDNS service is redirecting to the same IP in the posts above, just got off the phone from technical support to whom wasn't that great as the CS rep didn't even grasp the fact i was reporting something to them, instead they was rude and when i asked for a Supervisior hung the call.
So what ever is happening netgear it needs sorting.
Edit: Seems NO-IP is aware of the issue and working with Netgear already
- Jin357Oct 28, 2017Guide
Awesome, thanks so much! Hopefully it'll be resolved soon. Have a script checking it every minute.
- pvraduOct 29, 2017Guide
Hi,
it seems sorted already. Got some messages from my monitoring that websites are back online. Which means that my XX.mynetgear.com domain is now ok. Check yours!
Cheers,
Radu
