pvradu
Oct 28, 2017Guide
DDNS not working for Mynetgear.com domains. Domain owned by Network Solutions LLC
Ok, discovered this morning that mynetgear.com it's registered by NetworkSolutions LLC. http://whois.domaintools.com/mynetgear.com Registrar Network Solutions, LLC. Registrar Status clientT...
- Nov 08, 2017
Hi,
problem was solved 1-2 days after posting the message.
solidus1983
Oct 28, 2017Initiate
I am also having the same issue where the DDNS service is redirecting to the same IP in the posts above, just got off the phone from technical support to whom wasn't that great as the CS rep didn't even grasp the fact i was reporting something to them, instead they was rude and when i asked for a Supervisior hung the call.
So what ever is happening netgear it needs sorting.
Edit: Seems NO-IP is aware of the issue and working with Netgear already
Jin357
Oct 29, 2017Guide
Awesome, thanks so much! Hopefully it'll be resolved soon. Have a script checking it every minute.
- pvraduOct 29, 2017Guide
Hi,
it seems sorted already. Got some messages from my monitoring that websites are back online. Which means that my XX.mynetgear.com domain is now ok. Check yours!
Cheers,
Radu
- JeffreyWigginsOct 29, 2017InitiateAgreed as my site is now working remotely again
- Leos1Oct 29, 2017Guide
Looks like DDNS recovered. Thanks to everyone involved !
- SlimDOct 29, 2017Aspirant
DDNS is stilll not working for me.
I can login to noip and, as others in the early part of this thread state, the IP is correct there, but pinging the DDNS name (xxx.mynetgear.com) yields the generic (and error) ip currently linked to mynetgear.com (208.91.197.27)-
Also, noip says they are still investigating and will update when they have more info
http://status.noip.com/incidents/63cgdcwykdt1
Thanks to those who reported this issue.
- JamesGLNov 08, 2017NETGEAR Employee Retired
Hi all,
This issue should be working now. Can you confirm or if you still have any issues.
- pvraduNov 08, 2017Guide
Hi,
