Rmpiot
Jun 09, 2021Aspirant
Deactivating Router function on Nighthawk AC3200 (C7800) Modem Router
I need to turn off the Router functionality on my cable modem/router Nighthawk AC3200 (C7800) unit. The family was complaining about the wifi coverage in our single story house, so I purchased the Go...
imlemuel
Sep 13, 2025Aspirant
Just because you're right (or at least partially right) doesn't mean you should be a dick about it. HIS description of the problem and his description of how he solved it was far more helpful to me than your snark. Be better.
