HaLot
Mar 04, 2017Aspirant
Debrick unresponsive R7000 after flashing DD-WRT
I am a newbie. After flashing DD-WRT, I tried to restore factory firmware. I used the dd-wrt upgrade function to flash .chk file downloaded from official page. It was successfully installed. But afte...
- Mar 04, 2017
Have you RESET the router AFTER flashing the NG f/w? Hold in the hidden RESET button for at least 30 seconds. See if that helps.
If you can PING 192.168.1.1 I'd think it isn't bricked? Does 192.168.1.1 show as the GATEWAY IP Address when you issue IPCONFIG /ALL in a CMD prompt?
Possibly 2 better places to ask about this would be:
http://www.dd-wrt.com/phpBB2/viewforum.php?f=1&sid=4be2bcb5a14c52f50f67322c5615e347
or
https://www.myopenrouter.com/forums/r7000-open-source-firmware
IrvSp
Mar 04, 2017Master
or
