sbutler210's avatar
Dec 18, 2021
Delete a Wifi Band (Apple iOS, not Windows)
I mistakenly set up two 5GHz Wifi Bands when I initially did the setup so I now have two names relating to the 5GHz band.   I want to delete the one I set up by mistake but I can't find any instruc...
  • plemans's avatar
    Dec 18, 2021
    You "have a setting that you want to delete"
    If you don't want smart connect, you can simply change the other 5ghz bands name.
    And if you don't want the 2nd 5ghz band, you can disable it. But that kind of ruins the point of having a triband router.
    So I'm not sure exactly what you're wanting from this.
