OldBob's avatar
OldBob
Luminary
Aug 11, 2022
deleting (not disable) a guest account on Nighthawk
How do I fully delete a guest account set up on Nighthawk router?  I see I can turn it off but how do you fully delete?
  • FURRYe38's avatar
    Just disable it. It's just a feature that enabled the Guest Network portion of the routers wifi is all. Turns OFF this radio portion of the router.
