OldBob
Aug 11, 2022Luminary
deleting (not disable) a guest account on Nighthawk
How do I fully delete a guest account set up on Nighthawk router? I see I can turn it off but how do you fully delete?
- Aug 11, 2022
Just disable it. It's just a feature that enabled the Guest Network portion of the routers wifi is all. Turns OFF this radio portion of the router.
