Marknaghsh
Aug 04, 2022Aspirant
Deregister R8000 for new home owner
I need to deregister my R8000 router for a new owner. On my end is says it is already registered and on his end it says the same thing. I sent an email to customer support with no response. I never r...
Marknaghsh
The issue is I’m already out of the home and do not have the password for I only used the nighthawk app to manage it. He wants to register so he can change the admin password and he cannot for it needs to be unregistered first. I hope that makes sense
michaelkenward
Aug 04, 2022Guru - Experienced User
He does not need to register anything to change the admin password.
Indeed, you should he wiped out your password when you passed on the router. It is a trivial task:
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
That restores the router to the default password settings listed on the router itself.
- MarknaghshAug 04, 2022AspirantThank you. That’s what I told him, but kept coming back about deregistering it. I see he changed the email address so think it’s settled now.
Thanks all!
