Arno_pseudo's avatar
Apr 13, 2018
Desactived MAC acces control for WIFI Guest
Firmware version 1.0.2.46 Hi, I want to stop the acces control on mac adress for the guest. I just want control the mac address for the internal network, but not for the wifi guest ? How can I do ...
  • schumaku's avatar
    schumaku
    Apr 13, 2018
    Salut Arno,
    As far as I know the Netgear router (any older R6xxxx, Nighthawk, Orbi/Obi Pro for routers and APs) MAC Access Control system does not make a difference between the normal and the guest SSID. C'est un "design" très limité, n'offrant pas de flexibilité à mon avis.
    NaderAAbhayB and johngm (for Orbi Pro) - this is an absolute valid use case: Trusted LAN and WLAN SSID for trusted MAC only, guest network for any MAC address - advise please.
