Bill721's avatar
Bill721
Tutor
Jan 15, 2019
Desktop Windows 10 Internet connection delay only when doing a RESTART (Nighthawk X4s R7800 Router)
Desktop Windows 10 Internet connection delay only when doing a RESTART. Works fine after doing a shutdown, but RESTART still has Internet connection delay. I have updated the Lan driver from ASUS my...
  • Bill721's avatar
    Bill721
    Jan 15, 2019
    Thank you for the quick reply.
    I'm pretty sure I have it fixed.  When I looked into the windows updates I saw there was a number that needed to be done so I updated them and the issue went away.  I think it stemmed from the fact that I had reimaged the machine from a previous image, because of another problem.   Let's hope for the best and thank you for your input.
    Bill
