Anoninspain
Aug 22, 2021Follower
Device keeps resetting
I correctly setup my Extender and use it for often several weeks., Then for no apparent reason I notice that all the complete row of LEDS are flashing. My manual says that device is trying to do a f...
Aug 22, 2021Guru - Experienced User
I'd try reinstalling the firmware (or an earlier version). If something is corrupt in it, factory resetting only clears out the old settings, it doesn't reinstall the firmware.
so try reinstalling firmware and doing the factory reset/reinstall process.
