Aiyubb7
Aug 01, 2021Aspirant
Device light not on for AC 750 even though Ethernet is plugged in
My wifi extender is plugged in and connected to the wifi. But when I try using it on my Xbox One, the device light does not seem to be on, even though an Ethernet cable is plugged in. I thought the Et...
Aug 01, 2021Guru - Experienced User
The label wll have the model number.
did you try other devices other than the xbox?
Did you try factory resetting and reinstalling.
If you reinstall, I'd highly recommend reinstalling using the installation assistant and not wps method.
- Aiyubb7Aug 01, 2021AspirantHow do I do the reinstallation? I’ve looked online how to, but I’m still a bit confused on how to.
