tron76
Mar 09, 2021Tutor
Device limit issue
I purchased this router in January. Worked great until I got more than 15 devices connected. Once I started to get more than this, devices would show they were connected to the router but without ...
Mar 09, 2021Guru - Experienced User
What firmware version are you currently on?
What modem is it connected to?
tron76
Mar 10, 2021Tutor
Currently, 1.3.2.124, but I've also used the latest and 2 Versions before. The modem is a Motorola. It is fine because I used the old modem today and worked fine.
- michaelkenwardMar 10, 2021Guru - Experienced User
That is a brand, not a model. Motorola has made many modems over the years.
- plemansMar 10, 2021Guru - Experienced User
Like michaelkenward said, motorola is a brand. What actual model is it?
Another thing to try would be the downgrade. You only went down 2 versions. And you didn't put if you reset afterwards. If I was going to recommend a firmware for the R7000P it'd be the 1.3.0.20 version. Its the version prior to netgear armor.
If changing firmwares, I'd recommend doing using a hardwired connection, a factory reset afterwards, and to make sure not to install using a backup configuration.
- tron76Mar 10, 2021Tutor
It's a Motorola E31T2V1. Didn't think it mattered since the issue only showed up after iConnected more devices.
