Roberto_LDR
Jan 04, 2022Aspirant
Device Manager Not Working
Hello, I have a Nighthawk AX6 AX2700 Modem Model CAX30 and i have the Nighthawk app that isnt properly working. The Device Manager tab isnt letting me remove my son's nintendo switch from the blocked...
Jan 04, 2022Guru - Experienced User
Netgear has set up a community forum specifically for the Cable Modem products. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
Thank you.
